Results 1 to 16 of 16
Hybrid View
  1. #1
    Jack's unrated profile. bizerg's Avatar
    Unhappy Spire LED Fan; Help Needed!
    , - Spire 120mm 12v LED , (ground, +12V, signal speed signal ). , , .. 4pin , , .. 3pin . , , ... , , . .. , .. , ... ??
    MB AsRock B450 Steel Legend | CPU Ryzen 5 2600 3.6Ghz + DeepCool Gammax L240 AIO Liquid | VC ASUS ROG Strix GTX 1070 8GB OC Gaming | RAM Kingston 2x8GB 3200Mhz HyperX Fury RGB | SSD Crucial 500GB MX500 | HDD WD Black 2TB | PSU Be Quiet! SYSTEM POWER B8 550W | DeepCool Matrexx 50 + 4x120mm ARGB FANS
  2. #2
    Registered User marto96's Avatar
    Quote Originally Posted by bizerg View Post
    , fan ? 5v 7v molex.
    ASRock B450M Pro4 / 5700X@4.5GHz / MSI RX 6600 XT Mech 2X / be quiet! Dark Rock 4 / 2x16GB FlareX 3200MHz CL16 / FSP Hydro G Pro 1000W / Samsung Odyssey G5 S27AG50
  3. #3
    12 ,7 5v , 3pin fan ..
  4. #4
    Registered User lizart951's Avatar
    , 3 pin .
    Gigabyte Aorus pro z390 /Intel Core I5 9600K Lian Li Galahad 360/Kingston HyperX 16 GB/Asus GTX 1070Ti /3.5 +Tb NVMe/HDDs /Corsair RM750x /Lian Li O11-Dynamic /AOC C24G1 /Razer Kraken TE Bassilisk Ultimate ,Ornada Chroma
  5. #5
    , FAN_PWR -.. "Each Channel Supports Up To 18 watt".
    .: ot ".. recommended only for constant speed fans. Do NOT use on any thermal controlled, or adjustable speed fans." , , . ..
  6. #6
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Copyright © 1999-2011 . .
