Results 1 to 16 of 16
Hybrid View
  1. #1
    Registered User
    HELP! ( AC97 sound )
    Imam edin mnogo gaden problem!!!!Zna4i imam comp t-bird 900 s gigabyte 7ZM s vgradeno audio Advance Ac97.Kato si sloja win98 se vsi4ko si e normalno.Ama kato sloja winME ili winXp driverite mi ne stavat.Na disca pishe 4e ima a vsushtnost ne stavat.niakoi moje li da mi kaje niakoi site ili niakakvo predlojenie za reshenie na problema.
    Predvaritelno vi blagodaria
    [Mod. Edit @ Dreamer: ]
  2. #2
    Cowboy from Hell King Nothing's Avatar
    HEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEELLLLLL LLLLLLPPPPPPPPP!!!!!!!!!
    e hubavo de na WinME ne stava li s driverite za '98 to WinME si e chisto 9x i na '95 driveri da mu haknesh pak sha raboti (v povecheto sluchai)
    Dig for gold
    Dig for fame
    You dig to make your name
  3. #3
    Ghost Member G-Point's Avatar
    Legacy Audio-. .
  4. #4
    Registered User
    King Nothing (07-01-2002 01:14):
    E da ama ne nestavat to4no tva e 4e i taka ne stava.
  5. #5
    Bombera's Avatar
    Abe ima nqkwi razliki w drivernite arhitekturi na Me s wsichki ostanali 9x, ama ne znam kvi. Systo i na 98 i 98SE edna ot druga. SB Audigy driverite ot diska s platkata omazwat 98FE. ne staa duma za poddryzkata na WDM driveri. Ima nesto drugo
    EVGA X299 FTW K|i9-7960X@4.7|4x8 Patriot Viper Steel 4000|GTX 1660 Ti|970 EVO 1 TB|Seasonic Focus GX-1000|Xigmatek Elysium|
    Rampage IV Extreme BE|E5-1680v2@4.7|4x4 HyperX 1866|Cougar Aqua 240|GTX 1050 Ti|970 EVO 1/4 TB|CM 850 SilentPro|HAF-X|
  6. #6
    Pesho's Avatar
    http://www.realtek.com.tw/ ?
  7. #7
    Registered User
    Ave nishto ne stava Lagesito na dunoto e izkliu4eno a sus driveri na realtek suhto ne stava.
  8. #8
    WDC bronze medal ballroom Metanoia's Avatar
    Drivers
    . . Rendition V2200! , ...!
  9. #9
    conscientious objector Tarambuka3500's Avatar
    Hmm.
    sto ne obqsnish po-podrobno kakvo "ne im stava"
    ne se instalirat li, zabivat li, ne gi razpoznava li?
    probvai s windowsupdate, tam ima po-nov driver deto se svalq avtomati4no
  10. #10
    The Memberest One Empy2Strah's Avatar
    PC ACORP KMM1 97 - ACORP - GigaBbyte sa .
    2 - Sound blaster - - - !
    WinXP CD-ROMa - , - -
  11. #11
    sto ne vidish na www.viahardware.com dali ne pishe nesto? Ili da svalish to4nite drivers.
    -- az ne bih svalil draiver ot site-a na Acorp i pari da mi davat
    samo nekoi BIOS eventualno
  12. #12
    Tarambuka3500 (09-01-2002 12:55):
    Hmm.
    - VGA - 640480 ... . V2200 98 Format...
    ... , , , Riva- 10 ( , ... )!
  13. #13
    4ekai-4ekai... ti si s Rendition V2200, taka li?
    ma 4e to negovite draiveri sa na 2,5 godini be, te horata ne sa i sanuvali za XP
    togava... Vzemi q smeni taz karta po dobre.
    Metadonia govori za sastia problem mai4e
    qvno nisto ne e ot audioto, ami ot video-to.
    Mojesh za bez pari da si namerish Savage4 ili Vanta, ako ne ti se davat pari i da si resish problema, pak i ste si zabarzash sistemata dosta. Osven tui tia driverz za 2200 sa bugavi i v otnoshenie na powersaving, az kolkoto takiva sam imal obiknoveno zaspiva PCto kato velze v powersave.
    Abe izobsto beshe mnogo hubavo kato izleze stoto beshe eftinata alternativa na Vudu, no ottogava minaha 3 godini pone.
  14. #14
    Registered User
    A ve moq problem ne e s VGA-to az sum s GeForce2MX400.Problemat e 4e kato si sloja driverite pod winMe vsi4ko se instalira normalno a zvukat ne trugva.
  15. #15
    Tarambuka3500 (12-01-2002 16:21):
    V2200 ... Jaton Riva128ZX - !
    - , , V2200, !
  16. #16
    Registered User
    , . , ! Win ME
    ..... Win : - - , , -. , Windowsa 1 . Win 98 SE .
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Copyright © 1999-2011 . .
