Results 1 to 10 of 10
Hybrid View
  1. #1
    ﮔ ﻼﻵﻴﻲﻱﻬ ﻫﻪ ﻨﻠﻝﻜﻚﻗﻖ ﻏﻎ ¿ TheThing's Avatar
    Question nVidia Display Settings - Help Info !?
    1- , AXLE 6600GT
    Antialising Setting (AA) - , Info
    Anisatropic Filtering (AF) - , Info
    Image Settings (IS) - High Performance , High Quality - - FPS RAM-. !
    Vertical Sync - , Info ( ...)
    Force Mipmaps - , / / !?
    Conformant Texture Clamp - , On
    Extension Limit - , On/Off
    Trilinear Optimization - Mimpams Trilinear !
    Anisatropic Mip Filter Optimization - ,
    Anisatropic Sample Optimization -
    Triple Biffering - On
    Negative LOD bias - Clamp/Allow -
  2. #2
  3. #3
    AA AF ! :P
    - Extension Limit, Trilinear Optimization, Anisatropic Mip Filter Optimization, Anisatropic Sample Optimization, Triple Biffering Negative LOD bias - - - ! , !
    , ... Titan Quest, FEAR, FlatOut 2 - .
    EDIT:
    !? 1- ( ) ( ) ... !?
    It's not about to be the best, it's about to do your best.
  4. #4
    Registered User
  5. #5
    Night geniusloci's Avatar
    Riva Tuner - . , , .
    Trilinear Optimization, Anisatropic Mip Filter Optimization, Anisatropic Sample Optimization, Triple Biffering Negative LOD bias - , .. ( )
    hardwareBG Tem Member
    | RC , | PC hardwareBG.com |
  6. #6
    Januari, ... !?
    GeniusLoci - INFO !
  7. #7
    Nvidia.
    BG, , .
    ASRock X99 Extreme6/3.1 | Core i7 6950X | 32GB G.Skill DDR4-3200 | Samsung 970 PRO 1TB | MSI GeForce RTX 4080 Gaming X Trio
  8. #8
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Copyright © 1999-2011 . .
